redline8300
- May 25, 2008
- 65
After I changed out the Mallory distributor for the duralast, the Bronco ran great. I took it for a spin and after about an hour of driving it died like a light switch was turned off. Prior to that oil pressure was about 40 lbs and the water was 190 degrees.
She'll crank but not fire. Noid test shows signal to the injectors, fuel to rails, and without a plug wire installed, the spark jumps from the dist. to the intake.
For some stupid reason I disconnected the ecu and the only codes that come up now are the emission ones.
I changed the coil with a new one and no change. Reset the timing per the balancer and no change. One thing I noted was if I twisted the rotor with the key on, the fuel pump and relays would cycle. I changed out the new dist for the old one and it still won't fire.
I checked the RJM fuses and all were good.
