Didn't mean to confuse you guy's... much. ;D
Let me give you the reasoning behind my reccomendations and you can see how they apply to you.
1) Not many people have the ability to sandblast a full dash. But regardless, the second that metal is blasted white clean, you start the corrosion process. Also, yard sandblasters aren't well known for keeping their water traps clean. So you need to apply a protective coating on the bare steel the day it is blasted. Wash primer is easy to apply and will give you weeks of protection while you finsh up preping some other parts.
2) Sanding the steering column smooth will more than likely produce some bare steel around any sharp edges. While you have the wash primer out, go ahead and spot wash prime the bare areas. Won't hurt a bit to get it on the rest of the column.
3) My choice for fiberglass is epoxy primer. Since I need to mix some up to spray a couple parts, I'd go ahead and hit the dash and the column also. Take about 10 minutes and will add significantly to a guality job.
4) Sealer: Surfacers/sealers have a much tighter molecular structure than general purpose primers. Specifically, they aid color holdout and surface smoothness (little orange peel). Why bother? The sandblasted surface will have a .05-1.25 mil surface roughness from the blasting. That blasted surface will want more primer applied in order to "look" like the other parts being coated. If not enough sealer alone (with no other primer applied) is applied to the dash, it will appear less glossy than the other parts because the sealer was sucked into the blasting profile of the dash.
If all parts looking the same was not the focus of this project, I'd probably not responded with a second posting.
Allens recommendations are easier to accomplish, cost effective, and will more than likely lead to satisfactory results. There, I just talked myself into taking Allens advice. Let the project commence.
