Antenna location
Jake51
Newbie
Hi,
Hoping I could get a little help. Looking for measurements showing the location of the antennae assembly on the drivers side before any drilling is done so I can make sure it’s going in the right place. Appreciate it!
Tom
Jdgephar
Are you set on a stock look? If not, there are some nice, more hidden antennas or windshield mounted ones that don't require holes in your new fenders.
Sent from my SM-G981U using Tapatalk
J
Jake51
Newbie
Sorry, relatively new to the site, should have searched first as the info is already out there.
Thanks,
Tom
Fostertn
Columbia
I have enough detail on location, but am curious if you had any trouble drilling the hole? I have a Bronco shop manual that advises a 1.187" hole and location, but that puts the center point slightly on the downside slope of the fender...too bad it cant just be at the peak of the fender where there is less chance of screwing up the drilling of the hole. Any suggestions? I assume you found a way to safely drill that hole. I made the mistake of painting before installing the antennae!
