Antifreeze overflow, overflow (HELP!)*UPDATE PROBLEM SOLVED*
67PONY
SE Missouri
feitctaj said:
Another way of getting air out is to fondle your upper radiator hose with the radiator cap off, this will help to remove the air.While it is running.
Pardon me for butting in, but I thought fondling your hose while burping was standard practice also.
Sorry, couldn't resist..... ;D
Jeepster
adambronco74 said:
Jeepster: I'll give the timing a shot. Just out of curiosity though, how could timing being off cause this? Just a lack of synchronization of the waterpump?
Ed and Case: Thanks, I'll give those a shot.
Adam
I have no explaination for it. At the time my engine was (what I thought ) running pretty good. I also was miffed at the fact that the timing mark was not jiving with what I thought it was suppost to be. I was having trouble with the coolant overflowing the bottle. I later found that the harmonic balancer ring had spun a little. So I timed by vacumm gage after I did all the stuff I mentioned earlier. That fixed it.
I'm not saying that is your problem....but it dosent cost anything to check it. You never know. I would never have thought that would happpen.
Dan
gearhead74
Tri-Cities, WA
I'm having the same problem with my '74 ( new rebuilt long block)
I have a post on broncofix.com with a couple diff. solutions. The last poster said he was having the same problem with his bronco. Took it to a radiator shop, they tested the antifreeze and found exhaust gases in it. This would suggest either: cracked block/heads, head gasket failure, or intake gasket leak.
Yesterday I pulled my intake and after I got the intake off I found two of the intake bolt bosses had partially crumbled and came apart (on the head) I pulled the head and I'm waiting for the new one to arrive. Hopefully it was a leaky intake gasket, although I don't see exactly how a leaking intake gasket could cause this problem.
michael welch
kent, washington
New to this forum but sounds like you put on new heads? Did you put the head gaskets on right? There is a front to the gaskets if you put them on backwards? I've had this happen to me.
A
adambronco74
Northern Colorado
PROBLEM FIXED!
I want to thank everyone who helped me. I'm pretty sure it was an air bubble in the system. I ended up running the engine up to temp for about 30 min with the cap off and it purged some air. I also have a new 16# cap and ended up drilling a tiny hole in the thermostat. Thanks again guys, you helped out alot!.
Adam
