DeezNCSU
- Mar 12, 2014
- 226
Wanted to see if there are any carb gurus in the Raleigh area that might be willing to help me tune one. I understand them generally speaking but have never tried tuning one and worry I'd make things worse. I bought a vacuum gauge and have a timing light and I would like to learn how to adjust it.
I've got a new to me '68 with a new Blueprint 302 with a few hundred miles on it that has a Holley Street Warrior 600cfm Vacuum Secondary Carburetor w/ Electric Choke.
Here is why I think it needs some tweaking...
1) When it hasn't been driven in a few days and I'm cold starting it, it takes a few minutes to finally start. It turns over repeatedly, sometimes will try to fire then won't, then eventually will. Haven't seen any fuel leaks or pinholes that would cause the fuel to drain out.
2) When it's cold, it stumbles a little if I'm at a stoplight and hit the throttle. It's just a quick stumble then it takes off.
3) I'm not sure if the choke is set correctly, maybe it is. Today I drove it, let it sit for an hour, cranked it and it revved up and idled high for a minute until I hit the throttle. It does that when cold, but figured when it was driven recently, it wouldn't need to do that.
4) Want to make sure it's idling right, not running too rich or lean.
