My '69 desperately needs new tires. I thought about staying with stock steel wheels and mounting some 31 x 10.50 x 15's on them but I don't think the 31's would do a great job of filling out the cut wheelwells.
Current plan is to get some BFG radial mud terrain or all terrains and mount them on 15 x 7.5 Bronco/F150 wheels. Wheels will be blasted and painted flat black first.
I will tidy up the rear wheelwells and trim the fronts and add flares front and rear.
From what I can tell from threads here, 33's should fit flared wheelwells without any issue.
FYI - suspension is stock; just aftermarket shocks. Sits a bit high in the rear, but I'm going to swap rear springs and/or add aftermarket front springs until it's level. Drivetrain is 302/3 sp/3.50 gears.
Thanks,
Scott
Thanks,
Scott
