Anyone Ever Build A Full Float 9"??
ebroncoman
Denver
Hey guys, has anyone out there fabbed their own FF'er 9"? I'm not talking about the Warn kit, that's to easy ;D Seriously, if you could use the same brakes and hubs as the front... Just order custom shafts from Moser. I started a similar project to this
http://www.bc4x4.com/tech/2002/ff9/
using a HD "banjo housing" and 31 spline 3rd member. I've narrowed the housing already, but the project just kind of stalled. I was just looking to see if anyone else had the same idea, pics??
airman
I have heard that they are leaky at the end seal.
Has anyone ever tried to use a triple lip seal instead of the stock CR single lip seal? The seal almost sits in far enough to have 2 stock seals if the thick spacer wasn't so thick. I love the idea of full float but I don't see me doing it until they dont leak.
I can't wait to hear that news some day.
Jeff in AZ
68ford
tubeworks build awsome offroad axle assemblies that are floaters. might looking them up and seeing if they have anything to help, crisman also makes nice rearends,but they are high dollar, about 10 grand if i remember right and that was about 5 years ago.
Stock car racing uses custom full floater 9" all the time. A quick check and I found www.quickperformance.com
I am sure that there are many others out there. I think Speedway even sells them. Hard part will be finding the correct 5x5.5 pattern
SteveL
Huge chevy guy
Hawthorne ca
with the FF they recommend you run without the outer seals and let the gear oil lube the wheel bearings. On mine the gear oil leaked like crazy out the hubs. I swapped to drive flanges and it cured the problem. I would think if you installed the outer axle seals and greased the bearings it would also solve the hub leaking problem.
ebroncoman
ebroncoman
Denver
That's kinda what I was thinking. The front wheel bearings are greased, why not the back? The fronts have a hell of a lot more load on them. -E
