Anyone have a pic of 67 Arm Rests installed
broncoP
I googled but couldn't find. Anyone have a pic of armrest installed on a 67. I have to drill couple holed. Believe my door panels are ftom a 66 that had a strap so arm rest holes don't quite line up
.94 OR
Do you need just a picture, or measurements where the bolts go through the panel too?
.94 OR
Not sure I have the correct door release lever, or oriented correctly, but works for my long legs.
okie4570
NW OK
Not sure which direction is right or wrong, but if you have a bench seat, it won't go forward all the way with arm rests like the ones in the pic above. I've seen them both directions.
.94 OR
With the wider part of the rest towards the front?
Interesting, but with my legs I had to have it towards the back to clear my knee and the steering wheel.
I also just looked through my factory supplemental manual for 1966 and the 1967 shop manual and they don't show an arm rest. The photos may be hold overs from the '66 model.
okie4570
NW OK
Same here, I've looked and looked through 66' lit and can't find an interior door pic lol.
broncoP
broncoP
Heres a pic of a 67 I found on ebay. The 67 I'm working on didn't have them but I was going to put them on
toddz69
This doesn't help but here are the pages for the '66 and '67 doors from the Ford assembly manual.
Todd Z.
tirewater
San Francisco Bay Area
Various pics. Two from Ford Bronco 4x4 Performance Portfolio, the other from a brochure reprint from Bronco Driver.
okie4570
NW OK
Wichitabronco was looking for a oem slightly worn driver side iirc, and I has a set but what I was calling the driver arm rest was damaged. Turns out his were turned opposite of mine, so it worked out lol. Toddz the third pic almost looks like in the third drawing that it shows the tapered end towards the rear of the door. Any chance the bench seat broncos were opposite the bucket seat broncos? That sounds very Ford like lol.
.94 OR
Kind of interesting where mine has 4 holes across the top and bottom of the panel and this one only has 3. Late or hold over from 66?
okie4570
NW OK
66 had none at the top. I've flipped my arm rests around since the pic was taken, so my bench seat will go all the way forward with the door closed.
