Anyone know where to find a Brake & Clutch lock?
MnkyBiz
Northern VA/DC
Driving my rig in DC will have me paranoid in a month.
I am installing the locking gas caps, getting the Grant removable steering wheel, have a remote battery disconnect, and am fabbing some Cam style Hood Locks.
Should I also search out a clutch/brake lock? Is it worth it? If they are good, where the heck did they disappear to over time!!!!
Thanks,
MnkyBiz
NYLES
Hurst calls it roll control.....set up for drag cars......but I saw one not long ago more of what your looking for Ill look for it tonight and see what I can find.
Look through the similar posts at the bottom of the page lots of info there.
cracker
Pueblo, Colorado
Contact Chuck @ BC Broncos. He has the brake line locks in stock and affordable to. I am using one on my 67 in place of the emergency brake, works like a charm. You do not want to use any of the solenoid activated "roll control" locks as the solenoid is not designed to be used for a long period of time. The solenoids will overheat and fail! The lock from Chuck is a manual valve, so nothing to fail and it is designated for use as an emergency brake.
SteveL
Huge chevy guy
Hawthorne ca
I have the one called brakelock. I think they are at brakelock.com.. Also TSM that advertises rear disc kits in most of the mags has one in their catalog. These are both the style that uses a key to lock all four brakes. Those cam lock hood pins suck. I ran em for a while and got tired of fixing em. Now just have standard hood pins in the holes.
