Hey, why don't you drop your EB off at my place for a couple of weeks, leave me the $1500 you'd spend on the Howell setup and then come back and get your excellently running EFI 302. I can put an SEFI setup in it, or could do a Ford TBI unit, your choice. <br><br>To tell the truth, the sensor inputs and actuators are the same, whether it's a TBI or SEFI unit, as long as it's an EEC IV system. But you do have the advantage of removing the TBI unit and putting a carb back on. Or you can trust the Ford engineers who designed the "limp home" mode to actaully have a clue as to how the system works and put an SEFI setup on.<br><br>The advantage to computer controlled advance.... basically, it will advance or retard the timing based of how the engine is responding to the programming. So if it needs a little more retard during a heavy load climb up a hill, it can do that without having to keep the timing retarded all the time to make sure it won't detonate under max acceleration.<br>Joe
