My current set up is the WH booster and bracket. Had the HD master on there and am currently installing a 1.25" bore master that doesn't quite fit under the hood, had to modify the booster rod, oval the mounting holes along with brake lines to get it to bolt up. haven't bled the rear lines yet. I have the big Ford dual piston calipers up front and Chevy JB6 calipers on the rear. Not sure if my brake pedal ratio is still at the manual height or not. Had too much travel and no stopping power. I want to run the vacuum assist set up for now and just came across this in my desperate search for a 1.25" master that would clear under a bronco hood.
