Aod Installed, Not Shifting?
American Pride
L.I.,NY
swaped in the 5.0 and AOD and used the lokar tv cable. I played w/ the cable but she wount shift out of first. (plenty of fluid)
Any sugestions?
bax
Old Member
Torque converter installed correctly?
telcolineman
AOD's are a strange tranny, My club rebuilt one for a member and it wouldn't shift either. If I recall right we had to run the rig on jack stands for a half hour or so before it started shifting correctly, Try posting your question on norcalbroncos.com for more info.
Best of luck
Jim
If the TV pressure is correct, then it could be a stuck valve. The AOD has a thin easy to warp valve body. Sensitive to improper torquing.
handsomerob
las cruces
My money is on the valve body. as broncobowsher said they are very thin valve bodies and warp easy if over torqued. The valves will also stick if fluid is not extemely clean.
FASTERDAMITT
Oceanside
If you end up needing a valvebody. I have a good one with an 3-4 shift mod ready to bolt in. IMO, I would not use a AOD without some 3/4 shift mod. It makes the AOD more of a performance tranny.
showthread.php
