aj
1. What vehicle would you get the AOD from to bolt in the bronco? (most sensible donor)
2. Are there any circuit boards needed to run the AOD?
3. Would there be any modifications required for the steering column?
4. Is there a special adapter required for the AOD to Dana 20 and is there a specific torque converter need to make it swap to the stock 302?
