I am tearing my 74 Dana 44 axle apart for a rebuild. I’m going to install the 78/79 Bronco knuckle/disk brake assembly. I need to order a new steering setup and wondering if the center to center measurement at the tie rod holes are the same as the stock 74 knuckles. I have tried searching on this site for my answer, but didn’t have any luck. I did read the 78/79 knuckles have 90 degree drilled holes for the tie rods, where the 76/77 Bronco knuckles are drilled at a slight angle. Some of the heim joint steering kits have a range of 48”-51” for tie rod stud measurement. I think I am in this range, but wanted to try and verify before ordering anything.
