Astro Hydroboost fitting size??
Nobody
Stanwood
I have an Astro Van hydroboost with the straight bracket. At the time I pulled it, I thought the lines were inverted flare, but now that it's been in the garage a couple months, I looked, and that's not the case.
So, can anyone tell me the type and size of the high pressure fittings? Also are there adapters available to go to AN-6?
CRZA1
Albuquerque
I think this topic has been discussed a bit. I would try the search function. I know you will find the sizes and even the part numbers from like summit or jegs for the AN -6 adapters. I think they are metric O-ring sizes. If I can find them and can figure out how to post a hotlink I will, but no promises.
Good Luck
Madgyver
Bronco Madman
1.6mm and 1.8mm and yes they have special adaptors that go to AN-6.
Check with your local brake shop or hydraulic hose shop.
supermottl
Indian Harbour Bch,
Mad,
I think you mean 16mm x 1.5 o-ring, and 18mm x 1.5 o-ring
Do a search and you find all the parts and part #'s from summit and/or jegs for aeroquip fittings and SS hoses... real nice stuff...
Madgyver
Bronco Madman
supermottl said:
Mad,
Thanks for the correction. I got a good memory but it's short. %)
Nobody
Nobody
Stanwood
Found on Summit
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=400274+304784&autoview=sku
