AstroVan wrong hose diagram?
PNW
http://classicbroncos.com/forums/showthread.php?t=131746&highlight=Astrovan+hydroboost&page=8
This is regarding the HP hose from the pump and the return hose that flows out of the HB to the ps box.
Post #109.... check it out... the HP pressure hose from the pump connects right next to the funky fitting with the O ring. There is another Astovan HB threadpost on this forum that shows the HP hose from the pump connects to the port on the HB that is pretty much, by itself, not next to another port.
Which one is correct. I think I asked this same question years ago on Dan Wheelers build thread...as one of these two drawings is incorrect. I'll find the other diagram so you can compare...
PNW
Here's an Astrovan HB...you can see that the pic Dan has in his build, the one Todd referenced are different that this one.
Which one is right?
I say its the pic, not the diagram?
JohnJohn
Richmond
To me... both the pic and the diagram you referenced show the same thing. The high pressure port that connects to the pump is to the left of the return fitting.
I have the Astro van HB in two Broncos and just walked out to my garage to double check.
That pic with the red and yellow lines could be a bit better.
PNW
I have it hooked up correctly, have for 8 yrs...I had a buddy over and he looked at the diagram and said the hose routing was different. I agreed with him so started looking on the web...
In the post---The canned ham pump has what looks like tubing sticking out at the top of the reservoir in the pic-looks like a small hose clamp on it. That line runs over the top of the steering shaft (in the pic) and connects to the correct HP inlet port on the HB. IS THAT where the connection is on the canned ham Saginaw pump-the uppermost fitting closest to the fill cap on the pump?
I thought that uppermost fitting on the actual pump was a return line?
PNW
JohnJohn... I quoted your reply below
"To me... both the pic and the diagram you referenced show the same thing. The high pressure port that connects to the pump is to the left of the return fitting."
LEFT when you are looking at the HB unit in the pic above??
Looking at the pic above (just trying to clarify) the hi pressure line from the pump to the HB is the port that is highest vertically (closest to the top) in the pic--correct? Physically closest to the gold colored reserve chamber... for reference the pic above has the pushrod laying at a horizontal (to eliminate some phone that's rotated it) with the vise grips attached.
There are 2 other ports and they are next to each other at the bottom of the pic.
Not saying anybody's wrong here! : ) I don't have a canned ham pump and can't verify if the fitting closest to the cap is the hi pressure fitting that runs to the HB. It just looks like a metal tube that in the pic shows a hose clamped to.
toddz69
Wait a minute....I looked closer at that diagram this morning now on my laptop instead of my phone and I see what you're saying. I don't think it's correct either! The top fitting on the pump reservoir in that sketch should be a return, not the feed to the hydro boost. The output of the pump is always at the bottom on the backside.
Todd Z.
PNW
Thank you...thought it was just me being ...well...me! :) I'm so freaking literal. lol
