67EB_in_619
I have this on my workbench and am going to be swapping the input shaft, but step 1 is put it in low/low... I can get rear into low.. I cant get the front into low. I shift the rear into low first (per Atlas instructions).. I spin the front output, rear output, case input.. I align the synchro gear.. nothing. I know it is aligned because if I have pressure on the shifter, it will rotate correctly and be engaged in 4low.. but as soon as I take the pressure off, it walks back to neutral.
I dont see any obstructions or interference or anything. It has the upgraded cast shift arms inside..
I dont know what else could be going on here... any ideas?
Here is a link to a video.
https://drive.google.com/file/d/1AhbhflSoDFhtkojDWhPe2lL_kR1HuWGr/view?usp=sharing
