Bundy
- Jan 10, 2009
- 2,045
Hi,
Just bought the MSD distributor and MSD 6A box to finally let the atomic control the timing as it was running without these before. I have all the wiring hooked up correctly, I think. It's a 89'-92' 5.0L 302 with a new-ish painless harness.
The 6A light is on and blinks when cranking. The tach is getting signal as it shows rpms while cranking but it just won't start. I removed the coil plug to the dizzy and had my buddy crank it over to see if the coil is making spark. It doesn't during cranking but as soon as he let's off the key I get a spark but that's it. I'm using the magnetic pickup wires (green/violet) and the white wire from the 6A is not connected.
What am I missing that would make inconsistent spark? The red wire on the 6A box that is responsible for turning the MSD on and off (not the red heavy power lead) is getting constant 12V from #620 circuit (coil) which the painless schematic indicated could be used for an MSD setup as 12V to the 6A. However, when cranking #620 circuit falls to only 8-9V and goes back to 12V when we stop cranking.
So basically I only get spark when we let off the key and the system gets the full 12V, or so it would seem.
I'm stumped. Any thoughts? Should I just run a new wire from the ignition switch to the MSD 6A?
