Bundy
- Jan 10, 2009
- 2,045
I'm finishing up my atomic EFI and there is one wire left to hookup that says it is required (without timing using the timing control feature).
The instructions state "This is the tach input wire for the EFI. It connects to the tach output
of an MSD Ignition Control or Ready-to-Run distributor to supply
an RPM signal. Note: This wire is not used when the magnetic
pickup wire is being used for ignition timing."
The thing is I don't have an ignition control box and my dizzy is a Mallory Unilite breakerless with three wires; green, red, and ground so do I use one of those to supply RPM singnal? I thought my tach gets the signal from the coil?
page 8 http://www.atomicefi.com/uploadedFiles/AtomicEFIcom/2900.pdf
