76, C4, stock column.
I seem to have a lot of slop in my stock, auto column shifter and don't seem to be solidly hitting D/N/R, etc as well as returning back to park the way I think it should anyway. I've also noticed that the indicator needle tends to float a bit. I've replaced the lock out plate, column sleeve (inc new spring), shift arm, and indicator at this point. I feel like it's somewhere in the column and not the transmission / lower linkage an seems to be related to the spring action on the shift not returning far enough out towards the dash to lock. For what its worth, same problem before I replaced all the parts mentioned previously.
Any thoughts? Thank you.
