[quote author=ktmrob200 link=board=5;threadid=8205;start=0#58090 date=1029844643]<br> For the final sanding before paint I always use 600 grit and wet sand with warm soapy water. Then rinse, blow off, wipe off with grease and wax remover, remask everything, blow off again!!, tack, and paint. I think the warm soapy water helps remove any chance of paint problems: fish eye, etc.<br>[/quote]<br><br>This is good advice, I forgot to mention it. Make sure to use a soap that doesn' t have silicon in it. The warm soapy water not only cleans as you sand, it helps the sandpaper not build up sanding residue. In the body shop I worked in, we used Tide laundry soap (I am pretty sure it was Tide!) and it always worked well. make sure to wash, wash and wash again and then wipe it down with wax and grease remover at least 2 or 3 times after sanding. I would never use a DA for finish sanding. You have to really have a delicate touch to use a DA correctly and it is easy to fork stuff up with one. Hand sand with 600 and you should be good to go.
