casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I'm getting closer to my C4 conversion in my 66 and was planning on using a 67 Mustang floor shifter in it. This conversion is behind a straight six so everything is going to move back a few inches. I'm not sure now that I want to go with the floor shifter. I love the look of it but I'm not positive how its going to fit with the early 66 transfer case shifter. I have not totally decided against the floor shifter but I'm starting to consider using a column shifter instead. If I decide to go column shift and can't find a good Bronco donor, Could I use an auto column out of an F150? What would be another donor option? I could find a Bronco column but I can get Truck columns cheap at my local pick a part. If I keep the floor shifter, Could I use a cable instead of the original mustang linkage to attach it to the Transmission so that I can put it where I want it?
