The next hang up in the AOD conversion from 3 on the tree is getting the new column shifter to work. I put in a 78 p/u tilt column and am trying to use one of my old shifter arms with a rod end threaded on to it to make the thing work. The problem is getting the indicator to line up and going through the full range from park to 1. It appears that the tranny has a different throw than the column and I bolted a slotted piece of flat steel to the shifter arm at the trans to allow for some adjustment, but can't seem to get the right combo. Has anybody been successful getting the full range on the column and having the indicator line up? I wouldn't have made it this far without your help. Any ideas or pics are appreciated.
