Hello All! i've swapped a 351 windsor into my 70 bronco and purchased an electric fan. i want the fan to automatically come on when it needs it and remain on until the coolant temp drops back to where it needs to be. i think the best way to do this is to install a 1 wire on/off coolant temperature switch that shorts to ground once the temperature has reached a certain temperature. (what temp should this be?) then route the wire to the ground side of a standard relay and have the relay turn the fan on.
is this the best way to do it or does it need to be a bit more complex than this? also, where/how do i add this sensor? can i do it inline on a hose?
