Trooper1276
Today I installed an electric pusher fan. Here is how it went....
http://www.flickr.com/photos/54965061@N04/7761791332/
I have replaced just about every cooling component in the Bronco and it was running very cool driving down the road. Freeway temps around 180 degrees. The only times I would have trouble would be in very bad rush hour traffic. So in my infinite wisdom I decided to add an Auxiliary pusher fan that would turn on when the engine started to heat up.
Went down to O'Reiley's and picked up a 10" pusher and then went to Auto-zone and got a fan controller that would turn on at an adjustable temp and also had an A/C switch for when I get some air installed. All went well with the install. I started at 10:45 and had the truck running again by 12:30.
The Fan is an extremely tight fit! I had probably 1/32 clearance on the hood latch. Everything worked as advertised and wired up nice and neat.
I then started the bad boy up and let it idle.....
Heated up quicker than normal and the fan came on at 160 degrees at the temp sensor. I adjusted the relay to try and get to turn on at around 190. Things continued to heat up... got up to operating temp and then I went for a drive....Driving down the freeway temp stayed at around 210. When I stopped it went up to 230 very quick. I was running around town with the temp gun and all the reading were accurate. I am very disappointed
. I really thought I had it beat.
http://www.flickr.com/photos/54965061@N04/7761794578/
I have just returned from undoing everything and now I'm back to Square one.
I would never have quessed that that fan would block that much air and run 30 degrees hotter!
I think next week I will try a smaller pulley....
