Replacing aux tank and straps. Unable to remove one strap. Do you need to separate body from frame to do so? Also new straps (at non-bolted end) where the "T" slides into the slot in the body looks to be too big. Does the "T" need to be modified?
Hey tarheel, I'm speaking for a 73',74' &77', the "T" should fit if it came from a Bronco Vendor. As far as getting the strap off, it should come out, the bracket the "T" goes into, on the years I mentioned will unbolt from the truck. No need to separate body & frame. Hope that helps!!
Good luck!!;D;D
