- Jun 5, 2007
- 1,764
I’m currently running hard lines along the frame. I’m starting out with carb. But have a 97 explorer I plan to pull apart at some point to go efi.
So with that in mind I want to install the hardline return now with the body off. And I may as well just run a return. But I’m having trouble finding what I want. Running Edelbrock avs 2
I either need a fuel pressure regulator with a return, or a fuel pressure relief/bypass. I’m not really finding what I need. Also using 6AN on it if that helps.
So if anyone has any idea where or what to get this accomplished, that would be very appreciated. I’m also (for now running a stock tank) and have no clue if I can just hook up the return to one of the vents for the return, or I have add a bung?
I’m wondering if this is what I need?
https://www.cjponyparts.com/holley-...F7xw-6BLiB4jmZjwMV5sx3Hjrc1bAfpgaApuhEALw_wcB
Or
https://www.holley.com/products/brakes/proportioning_valve/parts/6805147
Here’s a rough idea
Or
Here’s a rough idea
