AX15 Question
Mattchu
I found an AX15 for sale near me that originally came from advance adapters. On the invoice that the guy has it says 23deg rotation for XJ application. My question is are all AX15 transmissions the same? Or is this a different output housing? Will the wild horses kit adapt this kind of AX15 to the Bronco? I currently have the stock 67’ drivetrain 3 speed and the T-shift stock transfer case. Thanks for the help.
Matt
JB Fab
Matt
Advance Adapter has a template available to drill the other pattern in it if needed.
M
Mattchu
Turns out it it was drilled at the factory for both setups. It looks like it will work, one more thing to check off the shopping list! Thanks for the help.
