I know ya'll love photos so much, so this post is loaded with them.
Here's the story:
In early December I came across an ad on a local forum for a Dana 44 and a 9in from a 66-77 Bronco. The ad specifically stated the year range (66-77), that the axles both had 4.56 gears, and that the 44 had disks (meaning 76-77). Both assemblies were complete and they wanted $150 each. Well, if it's an Early Bronco width Dana 44 with disks, $150 was steal, right? I already had a 9in BB housing and third member, but I figured I'll come across someone that will need it someday. So, $300 wasn't a bad price for both... I should have taken a tape measure; the full-width 44 looks A-LOT smaller with radius arms, steering linkage and a sway bar bolted up to it. They offered the calipers and I accepted, but it's been two months, so I've given up on that.
So, the question is, "Did I get screwed?", but it becomes, "What do I do with the axles now?" I figure the 44 is perfect for narrowing and the WAH, but I still would like your recommendations.
Thanks in advance for your help.
Front end stuff, w/ auto-locking hubs.
Yes, It's an HP 44, it's just upside down in this photo.
Underside of 44 diff housing, any significance?
Yes, the c-bushing wedges are cast.
EB 9in in foreground, more recent purchase in back.
Full width axle bearing, I guess the seal is pressed on? Seals on both sides need replaced.
So, what do you think? Any recommendations for axle housing narrowing in the Denver area?
Thanks Again - Scott
Here's the story:
![108939in_Housings.jpg](http://classicbroncos.com/photos/data/500/108939in_Housings.jpg)
