brbuilder
- Aug 19, 2007
- 159
Finally got around to installing 6* axle shims and in true Bronco fashion it led to something else. Noticed that the drivers side axle seal was leaking. Coincidence or luck but it must have just started. Installed shims, replaced the seal and added gear oil. It took quite a bit of additional gear oil after installing 6* axle shims. Rotating the diff raises the fill hole above the bottom of the axle tubes. I assume my axle tubes now have about 1/4” of gear oil in them. Is this correct or should the level of the gear oil be 1/4”-1/2” below the fill hole so the axle tubes don’t partially fill with gear oil?
