justintime51
- Dec 23, 2019
- 7
So here's my dilemma. I'll be running a 77 f250 d44, with solo motorsports radius arms. I'm trying to set up the weld on wedges, and when I tighten the radius arms up onto the wedges, it wants to pull the wedges inboard. If I keep the wedges from moving, it pushes the axle to the passenger side, an inch and a quarter. Where i have the wedges now(about ¾" inward from stock f150 axle), the back of the arms want to spring outward, away from the frame. Has anyone ground the inside of the wedges to gain the desired angle for the radius arms? Or should I cut the original spring perch some that's cast into the pumpkin to locate the wedges to stock EB location?
1st picture is where I'd like to run them
2nd picture is as close to the pumpkin I can get without cutting.
Sent from my SM-G998U using Tapatalk
