Texanferever
- Jul 27, 2010
- 143
So my new axle wedges should be here today for a D44, and I don't have anything to look at to get measurements from, but here is my plan.....
I am going to get a measurement from the floor to the frame (where the raduis arms mount). Next I was planning to clamp the new wedges onto the axle loosely then raise ends of the radius arms to the measurement that I took from the floor to the frame. With the ends of the arms at riding height, I was going to put the diff cover perpendicular to the floor so the bolts on the cover will point straight up at riding height. Then I would tack the wedges in place, tighten the clamps, make sure both ends of the radius arms will touch the ground together when the axle is rotated. If they do touch at the same time, the I was going to take the clamps off, finish the welding, put the clamps back on, re-check the ends touch at the same time, and stick it back under the truck.
Anything I am missing here? I have already screwed this deal up once, so trying to avoid a third attempt!
