B pillar support replacement
BlueGhost93
San Diego
Hi all. Today I was evaluating rust on my 68 and upon looking in my fender wheel, it looks as though part of the B pillar support has rusted away but the B pillar itself is solid. What’s the best way to go about this? I really don’t want to cut the rear quarters out.
jeffncs
Raleigh, NC
Post some pics. I’ve had luck drilling spot welds and grafting the lower sections of both A and B pillars.
Taking this approach, the body remained largely / structurally intact but replaced the lower 1/3 with clean steel.
Side benefit, I was able to access, clean and coat the upper posts sections with primer and paint.
jeffncs
Raleigh, NC
I did my repair (as described above) very seamlessly after measuring 100x, avoided overheating the welds to avoid warping metal and some grinding.
jeffncs
Raleigh, NC
Many shops will use “Slick Sand”. It’s a high build, sprayable filler. It’s applies very consistently, covers sins and is easily sandavle to creat a super smooth surface.
Less high tech shops will just skim coat and sand getting to the same end point.
if there’s more than a skim coat, cut it out, clean the mounting surfaces and weld a complete new post in there. If it’s mostly metal, you have the option of total replacement or sectioning it in.
BlueGhost93
BlueGhost93
San Diego
Is there not a backing plate? What is this link for below. Maybe I’m just confused
https://www.wildhorses4x4.com/early...qM6RSKaFAWfV9I_tzT0jtCSmk82Erf80aAqTPEALw_wcB
