77RHINO
- Feb 22, 2011
- 308
Hey guys, while getting the new engine dialed in, I think the power made what used to be a minor problem a much bigger one..:-X..while driving under light throttle or coasting, I can hear some grinding/crunching noises from the back end that I used to only hear on occasion with the old motor, but now it has turned into nearly a constant noise. It's similar to what you would hear if a lug nut was rolling around in a center cap, but a much deeper/heavier sound. I am not sure what/how to check if its an axle or R&P, bearing, or what. Has anyone heard this before? I have searched and seen similar situations, but not seen any remedies on ways to check it out. The transmission (nv3550) and driveshaft/u-joints aren't more than 3 years old, and it hasn't been offroaded hard at all, just muddy hunting roads. I am just trying to get ideas on what to look for before I can tear into it. Its a stock '77 rear end, hasn't had a gear change yet. Thanks in advance for any input ya'll may have!
