Bronchopper
so the bronc started running pretty erratic at idle yesterday. it runs fine as soon as you open the throttle, but it will not idle. i just did a tuneup a couple days before. it ran great for about 2 days after the tuneup. then out of the blue would not idle and runs kinda rough and wierd below 1500rpm. i have found junk in the carb (bowl and needle/seat) before. so i cleaned out the needle/seat and the float bowl). that did not help. floats are fairly new and working right, and the float level is good. i also replaced the fuel filter after the problem started. I actually have 2 filters on it. a clear plastic type and the one that screws into the carb. the old one was kinda dirty, but not bad enough to keep if from running. so with the new filter on there, i notice that it barely gets a trickle of fuel and never fills the filter. it does it on either tank as well. so is this the fuel pump going south?
