Badge install
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I shaved my badges off years ago by welding the holes shut. I've come to my senses and decided its time to reinstall them. What size hole should I drill for the clips to go into? Thanks
Sent from my SM-G973U using Tapatalk
1970 Palmer
Maybe buy the badges and the barrel clips first then use a caliper to measure their diameter.
I just went through this with a new replacement fender and I can tell you that the 302 badge clips and the BRONCO clips are not the same diameter holes. It's easy to drill a larger hole in your painted fender, not so easy to fix one that is drilled too large.
John
Fitz24
Use Dbl Sided tape or a glue made for badges. Don't need to drill fender. I think I used a 3M adhesive on mine. Been 10 years and their still there.
bronkenn
Bronco Guy
Southeast Ohio
Have you considered using stamped nuts instead of the barrel clips? The hole size wouldn't be as critical.
