Bailie Bilt bumper install
jlylec
I tried to install my new (and newly powder coated) BB bumper the other night and I just couldn't get it to slide in. The arms slide in easy enough but where it starts to snug up it just stops. I'm wondering if my frame is bent or something. Can you guys tell from these pics? I'll post some more with the bumper in place a bit later.
bax
Old Member
Just do a little more test fitting and see what has to move. Chances are a few customizing blows with a hammer to the passenger side frame will fix it right up.
DuctTape
Bozeman, MT
My horns have weld burrs and are slightly bent. I'd try bfh first and if that doesn't work you may have to do a little filing, grinding etc.
One thing I learned early on with my bronc is that you can't expect parts to always fit perfectly. I can't count the number of times I've had to make modifications to brand new parts (or bronc) in order to make it fit.
J
jlylec
Oh yeah. I just wasn't sure if my frame was bent or it was likely weld burrs. I'd rather hammer the frame than grind the bumper honestly! I noticed what looked like paint drips on the frame that are obviously weld burrs. Crap. I can't hammer on the bumper without messing up the powder coat.
DuctTape
Bozeman, MT
I just looked at your pics and it looks to me like the horns are bent a bit.
TN1776
Once you massage your frame into shape do yourself a favor and plate those frame horns! Bad things happen when stock Bronco frames are asked to support the weight of plate steel bumpers, especially when winching. Seen a few EBs with nice aftermarket bumpers that just fall off due to a cracked frame after running heavy bumpers a few years. Not good.
J
jlylec
This sounds like good advice. I have no idea how to do that though. Do you have any pics of this or links? Or even just details of what exactly you mean? Thanks!
