Ball joint removal question
Dirtrod74
I removed all the necessary items to press out the ball joints on a Dana 44 disc axle. After soaking the ball joints with Kroil for about a week, they still won't come out. I purchased one of those ball joint press kits from a tool catalog retail store on Saturday. The "C" part of the press bent severely beyond alignment with the screw after only one use! Is this a lesson in you get what you pay for because I'm thinking of trying a press from OTC but, I don't want to lose more money if this will happen to their tool too. Anyone have experience with OTC's press kit or others that can handle the job? I'd like to hear about any other methods to get these ball joints out too.
dpmerrill
Springville, UT
Try heating the knuckles with a torch. It will take several minutes of heating, but that should free them up.
My ball joint kit is just an imported kit I got from Eastwood, but it's taken a lot of abuse with no signs of wear.
jason
harned, ky
did you remove the retaining ring on each ball joint? i made this mistake once and had to learn the hard way. also look and make sure you are pressining in the right direction. look at the shoulders on the ball joint.
i know that it sounds like i am stating the obvious, but they are common mistakes!
jbeyer
new york city
i rented one from auto zone. free with a 100 buck deposit. i tightened as far as i could and then whacked the end with the trusty bfh. it loosened up the rust very nicely.
69marquisragtop
Roanoke, VA
Like jbeyer, I too rented the Auto Zone ball joint press. Worked like a charm! Although not recommended by AZ, an impact driver makes it a piece of cake.
eds66bronco
Essex, Vermont
i'll second what jason said, i was standing on the end of the breaker bar when the dimly lit lightbulb came on in my head. i had looked at the setup a couple of times and still did it wrong. i got the cheapo harbor freight job but it survived my brain fart. when i turned the c press around i was amazed at how quick that rusted mess came apart %)
airman
Before I got my cheepy press from harbor freight I had to beat them out with a big hammer and a heavy peice of cold roll steel. I didn't have clips on mine nor was I able to put them on the new ones. I'm pretty sure that my ball joints won't be falling out anytime soon.
Keep soaking and keep applying pressure whether it be a hand press, a large hydraulic press or a hammer and a peice of steel, they will come out.
(If you use the hammer take off your watch and kiss the top of your hand goodbye for a day or so)
Jeff in AZ
D
Dirtrod74
A huge thanks to everybody that responded. Following all your advice and another press finally got them out.
