BC Broncos headers collector pipe, & AOD trans cooler lines interference?
Anyone have the combo of BC Broncos headers & an AOD? I installed cooler hard lines out of the trans today and just held the collector flange up to the tail of the header...pretty close between collector pipe and trans lines. It might work, but I figured I'd see if anyone has BTDT and found an interference problem. I'm using factory Explorer 5.0 cooler lines because the bends are so damn close to being perfect in an EB.
It may work, but I can't tell what angle the collector pipe will end up at since I have no exhaust yet....getting everything else buttoned up before taking it in to exhaust shop. If it does clear and not end up with the collector pipe resting on the trans cooler lines, they will be close, which leads me to my next question. I know Earls makes heat insulation sleeve for rubber hose(used it in the past), I'd guess there is also one for steel hard line.....any suggestions on a good one?
It seems like a lot of heat from the exhaust would pass right into the trans cooler lines, in effect negating much of the cooler's effect.....right? This is something I should concern myself with, right?
Just want to make sure I'm not sweating the petty stuff and petting the sweaty stuff......
