mine has stock body mounts so i go off frame to axle measurements. after my 3 year project, taking out a few times and adjusting ride height by adding then removing leafs. mine ended up 1in lower than stock(someone else comparing axle to frame and telling me) with 6-6 1/2in up travel from ride height. when the rear is bottomed, the axle tube is 1/4 maybe less from touching the bare frame rail. original bumstops and plates all gone. to get it this low i put the rear shackle bushing 1/4 in below the bed right at the rear of the body and moved the front mount up several inches. it uses all of a 3.0 16 inchtravel shock.(fortunate to have a friend at king to help tune, which i think is class 3 fail point, suspension really working like it should). one thing that helped a ton with raising the front mounts is i ended up (by luck) 0-1 degree pinion change over 18in unstrapped and less than 1/8 drive shaft plunge. i think plunge affects suspension movement greatly while under accel or deccel. your front obviously cant be as low as mine due to not being able to c notch for the trackbar and draglink at full bump. but still as stated every class 3 eb i have seen has been super tall. i have watched hours of you tube videos and still feel that if you look at what keeps eb(besides breakage) especially from improving speeds is not properly tuned suspension.
i also think the huge disadvantage of unsprung weight can be offset by increasing the weight of the eb. mine weight 5500pounds 40 gallons of fuel but no tools or anything. 2800 is the rear and 2700 in the front. i think all that weight especially in the rear more than makes up for it being a little slower by improving stability and suspension operation.
new front end is in the works, but here is a pic where you can see that keeping low ride height is totally possible.
check out the king(go figure)sponsored buggy at 42 seconds. never seen a slass 3 solid axle truck this smooth or a solid axle move so freely under a vehicle while the vehicle is so smooth. so it can be done.
http://www.youtube.com/watch?v=tBy7afq3fag
