chuck
mine has stock body mounts so i go off frame to axle measurements. after my 3 year project, taking out a few times and adjusting ride height by adding then removing leafs. mine ended up 1in lower than stock(someone else comparing axle to frame and telling me) with 6-6 1/2in up travel from ride height. when the rear is bottomed, the axle tube is 1/4 maybe less from touching the bare frame rail. original bumstops and plates all gone. to get it this low i put the rear shackle bushing 1/4 in below the bed right at the rear of the body and moved the front mount up several inches. it uses all of a 3.0 16 inchtravel shock.(fortunate to have a friend at king to help tune, which i think is class 3 fail point, suspension really working like it should). one thing that helped a ton with raising the front mounts is i ended up (by luck) 0-1 degree pinion change over 18in unstrapped and less than 1/8 drive shaft plunge. i think plunge affects suspension movement greatly while under accel or deccel. your front obviously cant be as low as mine due to not being able to c notch for the trackbar and draglink at full bump. but still as stated every class 3 eb i have seen has been super tall. i have watched hours of you tube videos and still feel that if you look at what keeps eb(besides breakage) especially from improving speeds is not properly tuned suspension.
i also think the huge disadvantage of unsprung weight can be offset by increasing the weight of the eb. mine weight 5500pounds 40 gallons of fuel but no tools or anything. 2800 is the rear and 2700 in the front. i think all that weight especially in the rear more than makes up for it being a little slower by improving stability and suspension operation.
new front end is in the works, but here is a pic where you can see that keeping low ride height is totally possible.
check out the king(go figure)sponsored buggy at 42 seconds. never seen a slass 3 solid axle truck this smooth or a solid axle move so freely under a vehicle while the vehicle is so smooth. so it can be done.
http://www.youtube.com/watch?v=tBy7afq3fag
Here is a picture of my rear shackle. The rear travel is 15" at the axle. up caused a small dent in the fuel cell that is mounted on top of the frame. The down travel is limited by driveshaft bind. The also has 15" of travel, the up is limited by the oil pan and tie rod contact and the down by driveshaft bind. Because of the longer leafs I have more driveshaft plunge at full droop than at full compression. One extreme to the other the total plunge is about 1". The racer weight is 3740 front is 2140 rear is 1600 that was be for we added the spares, they weigh 95 each, that makes the rear 1795. We have the suspension working well at 90 and going over woops. Cornering is good but could be better. The real problem is the acc. control.
PS your EB is lower, I like it did you lower the body on the frame?
