bc broncos shorty headers
ryoungbronco
Belmar, NJ
Yes, there was a problem a few months ago where a few of us got headers that were without a few dimples that allow bolts to go on easily but I think that was fixed. They are nice and expensive. You'll have to fab up your own exhaust or buy the kit they sell. At this time the kits stop at the muffler end and don't exit out of the bronco. You'll need to decide if you want it to exit down, out the side in front of tire, out the side in back of tire, or straight back. My reaction so far is 50/50. They are easy to install (if you have the dimples), look nice (don't overheat them the finish will "cloud" I found out the hard way), they work with many combination of engines, and transmissions (this was the real reason for purchasing them).
78Scronco
I have them as well. Just got them last fall, mine had the dimples. but they are still a very tight space to install the bolts-doiable though. noticed the other day though that mine have a little rust water condensation spots on them though, it wiped right off, but thought it was wierd.
rtj731
I have them also, never ran into a "dimple" issue. They fit well, no clearance issues with a W 302.
70EB
Gig Harbor
Headers fit well with my 351W and ZF. I, unfortunately, got the earlier slip fit flangeless versions that myself and three separate exhaust shops can't get to not leak. Mine is hooked up to their 2-into-1 exhaust system. I will probably swap out the headers for either the newer BCBs ($$$:mad:) or WH. I also have surface rust on them (they have only been run very few times as this project has been in a constant state of unfinished due to multiple deployments - stored in my garage).
englewoodcowboy
Lick Creek Restorations
On the slip fit, try pulling them apart then coating the connection with antisieze but it has to have the copper base in it. This is what was used on some motorcycle slip fit connections and after it gets hot one time, it seals real well, the copper I think melts together or something. Had 2 different motorcycles put together this way with no clamp and I was surprised how well it sealed.
ilovemaui
Pacific Moist West
I'm curious on the length. Will the shorties bolt up to the stock exhaust flanges? My exhaust is practically brand new. I'm planning an EFI conversion and going to need the O2 sensors any way so maybe the shorties with the bungs are just the ticket.
HoosierDaddy
I have them also , love them .... except for the fact I accidently ordered the slip fits. The muffler shop refused to use them and just welded to the header ... kinda screwed if I ever need to remove them.
BroncoBernie
Headers
Nice headers, build is excellent.
M
mrborders
Got my headers tuesday and just now had time to test fit them and they DONT FIT
the head bolts are in the way so im probably just going to get bolts with smaller heads
my head bolts have 3/4 in heads and i probably need bolts with 9/16 in heads.
after test fitting them on my engine i tested them on my dads 408 and they fit great because the head bolts on that engine have smaller heads.
they look great but im not driving my bronco yet so im going to wait before i give my opinion on them
chuck
Ingram, Texas
First I stopped selling the slip fit headers because people just don't understand them. The design is very old and most big trucks still use the design. I still have them on my racer. The head pipe must have 4 1" long slots cut in the end that goes over the header and the band clamp must be right at the top for the pipe to stay tight and not leak. The headers with the 3 bolt flanges are made of SS so will not rust. The bolt dents are in all the headers again. With the 1 5/8" tubes the header bolts will be a chalenge to get in even with the dents. The only fix is to make smaller headers.
tx1ton
Boerne, TX
I'm running the WH's on my 71, they're made by JBA. Like them a lot though I had to clearance one fin on my ZF to allow easy bolt up to the collectors....no real issue if you have a good aluminum die grinder bit. The look and sound great, had no other fitment issues at all.
I know of several others in the LEBC running BC's headers and they are all happy with them as well.
When I go to putting headers on my crawler I'm really not sure which one's I'll go with....either seem to work just fine
Bronco4x4
I had the cylinder head bolts interfere with my BC shorties as well. I tried a long time to make the headers fit. The header attaching bolts were so close and I thought it was an alignment issue. I just ground down the flange to clear the head bolts. Of course, the coating was disturbed. I then touched up with silver exhaust paint. I hope this helps anyone interested. If I knew the head bolts had a possibility of interference, I would have saved allot of my time trying to start the header bolts.
englewoodcowboy
What barnd head bolts did you use? I am going to be purchasing the BC shorties and I also need new headbolts. Was looking at ARP's.
M
mrborders
i ordered new head bolts last night from summit. $45 made by arp
i sure as heck aint about to grind on a brand new set of $530 headers
change out the head bolts, bolt on the headers, easy fix
cant wait to hear them
