BC broncos throttle cable
LSUpete
Well......damn. I have a BC cable sitting on the shop counter, waiting to be installed.
JackHoleRacer
Phoenix
I am about two years into my 5.0 conversion, which I installed both Lokar throttle/kickdown cables. Easy to install with no problems what so ever. With that being said, a sticking throttle has appeared lately. Sticks on take off, and when I let off pedal while coasting up to stop light. Have chased the problem for about two months. No binding, pedal is free, gets a little better when I lube cable. I read online somewhere that the stainless cable cuts through the cable liner and causes this problem. I wonder if BC has this problem?
JackHoleRacer
Phoenix
Just talked to Mike at Lokar Tech, said Cables have lifetime warranty. They shouldnt wear through liner. Said he would do what it took to to help!
WOW! Something to consider on your purchase.
stlo
stlo
tulsa
yeah sorry i started this thread...lol...im going with the lokar...its 36$ from summint and the bracket is like 25$...thanks for all the input guys
beaux312
Hartford, AL
might have some dirt or sand in your cablemaking it bind or creating some drag
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Yes it does. I've been running the BC cable for about six years and when I try to lightly hit the throttle, it won't go anywhere. Have to mash it down and get too much gas. Looking underneath the dash, I can see the cable has started to saw through the fitting at the firewall, which does not make for a very responsive throttle.
ransil
I use carb return springs ( find in the help section ) on the throttle body on EFI setup's, BC provides a spring on the cable but it does nothing but rust.
jmhend
Love hearing things like this.. back to the meaning of true "customer service"
