BC Broncos Tie Rod Conversion
miket
Buckeye
Guys,
I have to replace the steering linkage and track bar on my 73 and have been looking at the BC Broncos setup (http://www.bcbroncos.com/steeringlinkage.html ). Has anyone installed this and what are your opinions? From the description it sounds like they have solved the need to ream the steering knuckle (which I didn't want to do). But in the description, it says reaming will be required. just looking for some input before I make a decision.
Lmfp
Lake Charles, LA
I have their setup on my bronco. You will have to ream it. The solution they're talking about has to do with a tie rod over conversion. Theres a pair of bushings they give you to make the studs seat correctly.
Lmfp
Lake Charles, LA
As far as my opinion on it. It seems solid but thats about all the info I can give you. My transmission died right after I installed it and my alignment was off...
PaveBronco
I went the TBP route and wanted the TRO but didn’t want to pay for a reamer; there was a thread somewhere on here with this link: http://www.ruffstuffspecialties.com/catalog/INSSTEER.html
I needed the TRO sleeves but looks like they come with the kit. The insert just needs a hole drilled...no reaming. I did recess the top of the insert so it sits just above flush with the knuckle and don’t drill the hole all the way though as the insert is a lot shorter than the knuckle and 7/8 is a big hole, meaning the nut itself isn’t much bigger in diameter. You need some knuckle meat for the nut and washer.
eastbaybronco
San Clemente CA
im suprised anyone orders anything from BCBRONCOS, i have have nightmares with every order and the rudest customer device. WildHorseses, but they are not the most customer friendly by far, TBP are always the nicest, just saying.
bchesley
Wow, I'm so glad you could contribute some input on their steering system. I am actually looking at it ordering it, but staying tie-rod under. I love the tapered bolts. Every time I have drilled a knuckle for a heim it has wallered out the hole and had slop in the steering.
M
miket
Buckeye
It is my understanding that either system requires you to drill out the knuckle...
Unless I am missing something.......?:?
PaveBronco
I miss spoke earlier, I got my steering from WH, just finished my drivetrain rebuild so I’ve had WH, Jeff’s, and TBP orders all mixed up in my brain. I think the consensus is that WH customer service is second to none, and you can get answers from them on this forum 24/7 it seems. But Tom’s is great also, along with Jeff’s. I’ve ordered BC stuff and never had issues, but we’re all human and have bad days. One of the reasons that makes owning a Bronco great is the community, they are involved and doesn’t matter how much money you make or how much you put into your rig everyone pulls together. That’s part of the reason I sold my Jeep, too many people and vendors and the TJ crew on the trails with their dealership modified rigs getting in all kinds of trouble.. I hate to use the word ‘Scout’ on this site, but those guys are a good bunch also.
M
miket
Buckeye
Ok....so I have been weighing the various steering linkage setups from each of the vendors. The previous owner of my EB said it had a two inch lift. I see that the stock drag link twists (rotates) the tie rod assembly any direction the steering wheel is turned. The joints are super loose. So in looking at the Y link kit from ruff stuff (http://www.ruffstuffspecialties.com/catalog/YLINK.html ), it appears the drag link connects to the tie rod itself and I wonder if I will have the same issue. I like this setup because of it’s price, I guess due in part that its really just a kit and cutting/welding is required.
In looking at the setup from bulletproof (http://bulletproofsteering.com/steeringsystems.html ) the drag link connects directly to the knuckle which to me is a better way to go and could provide better steering accuracy. Though I wonder how much of an angle their (drag link) rod end will take given that my drag link is at a more aggressive angle due to the lift.
In looking at the kit from BC (http://www.bcbroncos.com/steeringlinkage.html ), I see they fab up a drag link bracket and weld it to the tie rod. This puts the rod end (on the tie rod side) at a better angle…plus I don’t see the tie rod twisting as much. I like their joints as well.
My EB isn’t being setup for crawling…likely occasional off road…nothing extreme. But, I only want to do this once…give me your thoughts.
