BCB hydroboost question
bronco italiano
Years ago I bought the BCB hydroboost setup and am using it on my buddies EB build.
The end has a small area to weld up a rod (or thread with a die)?
Does anyone have the BCB setup as I cannot find it on the BCB site anymore.
-Not sure how the pedal to h-boost rod should be attached.
toddz69
Wow, I don't remember BCB ever selling a hydroboost setup, but maybe they did. It sounds like you have a hydroboost pushrod with the loop on the end cut off? Many of the hydroboost pushrods are of a diameter that they can be threaded with a 3/8" die and then you can use a threaded coupler and some jam nuts to install a threaded pushrod onto it. That's what I've done with the boosters I've used on my truck over the years.
For most of us, that's a safer and easier way to get the pushrod configured instead of welding.
Todd Z.
