BCB steering stiffener install
bigjhoov
nobody
The schematic I found for this kit doesn't really specify how this should be installed so I thought I'd share how I recently installed one.
First step is to knock out the existing sleeves inside the frame.
Next, chamfer one end of the new sleeves so they will sit flush inside the frame.
I then opened up the existing hole with a uni-bit until the sleeve fits through.
Next, insure that the sleeves sit nicely in the frame and that your bolts will run through. The frame has some ridges inside from where the two halves of the boxed frame overlap. This is the reason for the chamfer on the tube.
Next, I leave the bolts inserted from the steering box side, and weld in the sleeves.
I then made some weld washers, and welded them on over the new crush sleeves.
Finally, weld on the frame reinforcement plate. Take your time each step to insure that all your holes line up as best as you can. There is a good chance that you will have to chase your holes with a 1/2" drill bit to insure that your bolts will pass through the new sleeves, stiffening plate, and weld washers. Clean it up and paint it.
68rustbucket
San Marcos,TX
Nice! It looks like your doing this upgrade before you crack the frame. I know a few of us that waited until after to plate the frame.
