Bcbronco fuel line kit
savage
Bronco Nut
Renton
I bought the carbed deluxe fuel line kit. I was just wondering if anyone has installed one and if so does anyone have pics that they can post...does it follow stock location of the old fuel line?
Chief Master Sergeant
Retired U.S. Air Force
Put this kit on both my rigs. It's a good kit, but the bends didn't work for me. I ended up having to resend several places. The aluminum brackets are great. Just had to remove the old plastic pieces and tap the holes for the bolt. To dark to tak pics right now, but will try to remember tomorrow.
savage
savage
Bronco Nut
Renton
Thanks, it sound like it will work ,I kind figured I might have to tweak it a bit.
Fireball05
I will be installing this on Wednesday most likely. Will try to take pictures, and report back any notable findings.
xcntrk
NOVA
I have these too. I'm using the EFI version (includes the return line). The bends didn't really work for me either as I use a different transmission crossmember and had to mount high in that location to clear.
chuck
Ingram, Texas
The last picture above shows the return line mounted backward. Remember, if you re-bend a bend at one end of a line the other end will be off a lot. It may be neccasory to adjust them a little but try to get them in as they come to you. One little adjustment will require more and it is a very slippery slope.
savage
savage
Bronco Nut
Renton
I installed the break line front to back and had to tweak it a little bit,it was pretty close to the stock location only problem was the back part was bent the wrong way.so when I get the fuel line kit I figure I will have to tweak it to.Thanks for the pictures!
