Beefing up frame around steering box
mnido
Anyone have photos of how you may have beefed up your frame around the steering box connection ? I have a PSC rebuilt stock box and want to beef the frame up if you feel it is necessary. Thanks
DrLathrop
Fulshear, TX
Order a frame support plate from BC Broncos & weld it in place. The sleeves included will keep the frame from distorting under load. You will need a metal rod & BFH to knock out the factory bolt supports but they come out pretty easily with some persuasion. I had a local metal shop copy the plate & I welded it to the inner frame area also for added protection. I would imagine you could also plate the top & bottom of the frame for overkill but I would only do that if you are running a full-hydro steering setup with giant tires.
beaux312
Hartford, AL
this is what I did to the inside with 3x4x1/4 angle on the outside I made a plate out of 3/8"
Pedestrian
Bronco Missionary
I also recommend the BC Broncos reinforcement plate, excellent quality and fit perfect.
u10072
First pic is the outside
Second pic is the inner frame
Sleeves in between--
Monster Mike
Also check out anthony's steering box girdle at stonecrushersteering.com
I like how easy it is to install & it provides support to the entire box & frame
bknbronco
North Metro, MN
The BC kit is what i duplicated. I had my plates cut on a lazer and got the DOM tubing. I got about 15 bucks into mine, and that includes a second set of plates and DOM! In the first pic you can see where i cut and bent in the cross member so in the future i dont have bolt clearence issues if i go with a diff steering box. Also when i went to add my hoops i ran short of material and had to add a chunk. The second set of plates i made i added 3" of material to the outside plate. If you have access to a water jet or lazer i could get you the cad file probably.
68 Broncoholic
WA
After tearing the box off the frame I added 3/8" plate and welded it to the outside frame rail and its held up well. And its not in the stock location.
mnido
mnido
Thanks for your help, got mine done. Thanks
