Hello need to know best way to route power steering belt alt belt.. I now have dual groove water pump pulley and dual groove crank pulley.... Can I go from alt to crank to water pump , then ps to crank to water pump??
If both grooves on the pulleys are the same diameter, then yes that works good. Makes the water pump redundently driven. Loose either belt and you won't overheat.
If the grooves on one pulley are different diameter (say one is 6" and the other is 6½") then the belts will fight each other. This will take more creativity to get right.
