Ben's 73 Build Thread
jspurl3
Baton Rouge, LA
Thanks John! How is yours coming along?
I put the body on the frame yesterday for the final time and brought it home! I've been meaning to start a build thread for it but I'm so far behind it'd take a lot of uploading pics. Hahaha maybe this week!
mattyq17
Keep at it Ben, let me know when you are going to fire it up and I will come over and help.....or just watch and drink beer!!!
Bferrari
Bferrari
I GOT WOOD!
Just opened up the new custom drive shafts from Tom Woods. One step closer!
Bferrari
Bferrari
Have a few updates. Ordered custom valved shocks from fox. They took a little while to get but definitely worth the wait.
I had been pondering where I was going to stick my coil. I decided to do a little surgery to the power steering bracket to clean it up a bit. Then I bent up a bracket to mount the coil to the back side.
I want to ensure that I am getting proper air through my radiator to give it every chance I can to stay cool so I made up some side dams to seal off the core support to the condenser. I have to thank my good friend Nick for the suggestion!! ;)
Stuck the column in and fit the steering shaft.
Bferrari
Bferrari
I next proceeded with fitting and making my AC and heater lines. I ended up routing them so they were as hidden as possible. Steve came over tonight and we charged the system with nitrogen to check for leaks .... success! We then pulled a vacuum on it and let it sit a while, didn't bleed off at all. We will wait until the motor is up and running to charge it. Another check mark off the list!!
IMG_0540.jpg IMG_0542.jpg IMG_0547.jpg IMG_0548.jpg IMG_0549.jpg IMG_0550.jpg
Casey4wd
Austin, Texas
This is an awesome build!
Do you have any additional pictures of the dash? I am working on laying my dash out and trying to figure out how to get A/C, Double Din Radio and the other switches on it while at the same time moving the glove box and deleting the speaker and ash tray. Seems like you did all this on yours? Do you still have the defrost ducting behind yours?
Bferrari
Bferrari
It is a very tight fit and takes a lot of mock up. I made a cardboard box the size of the stereo, had the vintage air mockup unit installed and shoved everything behind the dash to try to verify prior to cutting and modifying my dash. The defrost duct is sacrificed in this install, I am only keeping the top portion of it. I will being doing something creative with the ducts .... remember, heat rises!
Casey4wd
Austin, Texas
Thanks for the picture! Will your doors still shut with the roll cage mounted where it is? Seems like your glove box still works and you did not have to move it, which saves a lot of usable dash area?
I was thinking of only using 2 A/C vents in the dash and then a double A/C vent right below the dash in the center. I have also thought about just using a small ipad as the radio. So much stuff and so little dash...
Bferrari
Bferrari
I bent my cage myself and the doors shut fine. It is conformed tight to the dash and close to the door to gain as much room as possible. The pic I posted looks misleading. I did have to move the glove box over, but only 1".
Casey4wd
Austin, Texas
It is impressive. Good work on the cage bends. Been a long time since I bent tube, but I might have to try that on mine to gain the additional space.
I am interested in what you are going to do for defrost?
Alpine makes a shallow depth double din receiver, but at $700, I need to find another way.
englewoodcowboy
Lick Creek Restorations
When you put vents in the dash like Ben did or I did on the Duck, the defrost duct hits the chopping block. No way around it, specially if you want to keep it symmetrical. Keep in mind hot air rises and it does not take a massive amount of airflow to defrost the bronco windshield simply due to its size. The red ranger I am building for a customer, we just tested the system on it today and I tossed the factory duct all together. It has a ton of flow out of the dash openings so do not worry too much about it.
